Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
F/stop is the unit to measure how wide open the lens is.
The number, I think refers to the F stop/focal length.
So a F/1.0 lens for a 50mm, will haven an opening inside the barrel of 50mm. A F/2.0 lens the hole how is 2/50 so it is now half the size. The math itself isn't important. You only need to remember the smaller number the better, and more expensive.
The bigger the hole, the more light can get in, means more control and more desirable, most of the time.
So a 50/1.0 is would be a BIG lens and expensive (large piece of glass) and a 50/1.8 would be a smaller lens, lighter and cheaper.
