- 20 Apr 2004
- Somerset
One engine out![]()
Sir I'm going to need to see more pictures of the Chevette please.
One engine out![]()
Same engine will go back in, just with the head given the proper treatment, some slight boring and forged internals popped in.
Living the life!
So I took the bumper off and began righting the wrongsI don't think he drives as sedately as you though.
No sign of the person who hit meSo I took the bumper off and began righting the wrongs
Sadly it’s likely due to tiny gaps/cracks on the outer side of the lens, one solution is to put PPF over it but I have none of that!Can you seal them better?
Yeh should be, a lot of water came out! I was prompted to do it after an indicator warning came up yesterday. Not keen on spending over £300 on a new unit currently!Is it ok if you keep on top of it?
They’re still drying out, leaving them as long as possible.My rears are LED and I don't think they would be cheap either, sounds worth the effort. All working now?
They worked fine yesterday even after the error, probs just a bit of water that caught it.
What car have you got?
