Crysis Remastered 2020
TNA
TNA
Caporegime
13 Mar 2008
Greater London
All depending how much it is of course .
Indeed. But even if it cost more than expected I would wait and get it on sale. But I won't touch it if it has origin integration like most games back on steam.
Also will have to see how it compares to the original with mods.
6 May 2009
I cant get the original to run anymore. All the "fixes" dont work for me.
Just installed it again now in Steam.
Nothing needed, jsut right click and play. Works perfect - DX10, 3440x1440, 100hz/fps. I just needed to change to windowed mode then back to fullscreen to force it from 50hz/fps to 100hz/fps with vsync & gsync set on in Nvidia control panal
The 2080Ti can actually run it at 3440x1440 in 8xAA at 100fps. I'm shocked. My 1080Ti couldnt at 100fps
9 Apr 2007
How did you get that resolution my CD copy maxes out at somethingx1200.
Permabanned
23 Apr 2014
Hertfordshire
Might grab it on steam actually then, only £4.50. :)
OP
25 Nov 2011
The KOP
If you testing early in the game, the frame rate is actually quite high but the more you play the worse it becomes.
This is all because its running maxed out on a single core.
18 Jun 2009
Kent
Did you see the new Neon Noir bench with the software RT ?
Looks very puuurty but my 1080ti struggles at 3440x1440
EDIT: FPS was 45-60
