Internet went down just now and thought it would be this outage but fortunately was just the M500 upgrade kicking in!
M500 has a profile of 575Mb/38.5Mb.
I have only had it a few days but I have seen 561Mb/38Mb
Is there any confirmation on that, as my contract states a max speed of 548/37Mbps. 99% of the speed tests I've seen from people on M500 are never above 550Mbps, of course you get anomalies on the likes of fast.com.
As usual the actual profile (max attainable) rate for their new package is faster than the headline speed of 500Mbps (i.e. max of 575Mbps download and 38.5Mbps upload), which is because Virgin Media over-provision in order to help ensure that the majority get the expected average performance. For example, Virgin’s previous top tier of 350Mbps actually delivered an average peak time speed of 362Mbps, thanks to over-provisioning.
There's no evidence in that article of a 575/38.5Mbps profile. If you could upload a few consistent speed tests throughout the day showing higher speeds then I may believe it. One-offs don't really count.
Over-provisioning has always been around 10% on each tier.
The profile assigned to your modem can be viewed in the web interface
Mines the same but never see those speeds even with one device wired in on modem mode.
I think if you did consistent speed tests throughout the day you would find it tops out around 540-550. The odd burst above here and there is no use to anyone really.
I was never under the impression I would get these speeds flat out all day long. I was simply stating what the profile for M500 was.
Down nr Leeds, the status page says fix eta 23:10. Might have to go outside ..... !!!!!
