And here's my new build... new home for old equipment...
MAIN SYSTEM – THE CHAOS ENGINE 4
• Monitor: 3 x electriQ 28" 4K Ultra HD HDR 1ms Free Sync Gaming Monitor (EIQ-284KMB-HDR)
• Processor: Intel E5-Xeon 1680 V2 8 Core/16 Thread @4605MHz Ivy Bridge (1.350v) EP/EX
• Motherboard: Asus Sabertooth X79 TUF Gaming
• Graphics Card: Sapphire Radeon 5700XT 50th Anniversary 8GB @2200/1800MHz (1.200mv)
• RAM: 64GB Kingston Hyper DDR3 1866mhz Quad Channel (3732mhz) @10-11-10-24-2T
• PSU: Leadex Super Flower 1600W GOLD 90+
• SSD & Storage:
WATER COOLING PARTS Chassis: Lian Li PC-O11 Dynamic (White)
Sleeved PSU Cables: Shakmods Premium sleeved cables (White).
• 1 x 24 Pin E-ATX Power Extension Cable (White)
• 1 x 8 Pin CPU Power 12v Extension Cable (White)
• 2 x 8 Pin PCIE Power Extension Cable (White)
• 2 x 6 Pin PCIE Power Extension Cable (White)
• 1 x Motherboard Pin (USB etc) Extension Cable (White)
• 1 x SATA Extension Cable (White)
• Water In-line Temperature Sensor: Barrow Black Digital OLED Display Thermometer - A66
• Chassis & Radiator Fans: 7 x AIGO Aurora C5 120mm RGB fans
• Water Pump: Barrow Water-cooling DDC Pump, PWM Combination Pumps, LRC 2.0 RGB
• Water Reservoir: Barrow Waterway LRC 2.0 RGB Panel (Front) Lian Li PC-011 Dynamic
• CPU Waterblock: Barrow CPU Water Block use for Intel X99 X299 Socket LGA2011 2066 Acrylic
• AURA RGB Light Copper Radiator Block LTYK3X-04-V2
• GPU Waterblock: Eisblock Aurora Plexi GPX-A AMD Radeon RX 5700/5700XT Water Block
• Waterloop Coolant: 3 x EK-Cryo Fuel Clear 1L Premix Water-cooling Fluid
• Rigid Fittings: Barrow 5 x OD14mm rigid compression level adjuster fittings (White)
• Rigid Fittings: Barrow 14 x OD14mm rigid compression fittings (White)
• Rigid Fittings: Barrow 11 x Rotary 90 Degree OD14mm Tube Compression Fitting (White)
• Rigid Fittings: Barrow T Virus Spiral Suspension tank LRC 2.0 RGB (black end with white virus) NOT USED YET
• Rigid Fittings: Barrow 14mm mini sealing ball valve with tap (white)
• Rigid Fittings: 2 x Barrow 14mm “time” series manual tightening lock sealing plug
• Rigid Fittings: Barrow LRC 2.0 RGB Flow Indicator
• Hard Water Tubes: Barrow 10 x OD14mm PETG 500mm clear rigid tubes
• Radiators: 1 x 360mm & 2 x 240mm Radiators (White)
• Chassis RGB Controller: Barrow 16 x Way MOLEX Power 5/12v LRC 2.0 RGB Controller with Remote
• Fan RGB Controller: AIGO Aurora 10 x Way SATA Power 5/12v LRC 2.0 RGB Controller with Remote
• Chassis & Motherboard Screws: 10 x M3 Aluminium Computer PC Case Fully Threaded Knurled Thumb Screws Bolts (Black)
• SSD & Storage:
• 1 x Sabrent 2TB Rocket NVMe PCIe 4.0 M.2 (3,500MB/s Read & Write, Windows OS/Applications)
• 1 x Sabrent 2TB Rocket NVMe PCIe 4.0 M.2 (3,500MB/s Read & Write, Games Drive)
• 2 x Samsung 840 Evo Pro SSD in RAID0 (Clone of main Windows OS/Application Drive
• 1 x 10TB Seagate Barracuda Pro 7,200RPM HDD (Backup Drive with downloads and archiving)
• 1 x 4TB Seagate ST4000DM001 5,900RPM HDD (Backup Drive with downloads and archiving)
