- 17 Sep 2007
- West Yorkshire / Market Bosworth
The S5 V8 sounds amazing in my opinion. A car I’d like to own just for the noise.
Is that the price you're being quoted now? I know with my RS3 whilst it was still in warranty the quoted cost was quite high, but then once it's actually due the quote dropped significantly.
I know it's a class down from the A4, but the RS3 warranty extension was only about £500.
My B9 S4 Avant was also about £550 for its warranty extension
Had some front suspension work done recently on my C6 A6 at a specialist it was a few hundred. Would expect it to cost significantly more at a main dealer.I know there are a lot of factors but does anyone have a rough estimate on fixing these adversaries on my Audi S5?
Both front Upper Suspension arm Bushes deteriorating
OFF side Front lower suspension arm inner bush deteriorating
OFF rear shock absorber dust cover incomplete
Are we talking hundreds or thousands? Will be done at a indy or audi specialist.
That’s good to know, do they send you something to extend?
That's going to depend on your engine selections - small engines like 1.5TFSI, 1.6TDI (and I think 1.8TFSI) will have a DQ200 dry clutch 7sp - these are the boxes that historically have presented more problems, though not sure if newer ones are as bad.
A 2.0TDI or 2.0TFSI will come with either the wet clutch DQ250 6sp or DQ380/1 7sp depending on age/model etc. which are all more torque capable and mostly appear to be reliable.
Generally if you see the engine torque is 250Nm or less, it's probably using the DQ200 dry clutch seven speed.
If you're looking at 150PS cars for example, in that scenario the diesel probably has the preferable gearbox, as it's over 250Nm and so gets the wet clutch gearbox.
Press Control (bottom-left), and then RPT.I’ve just loaded up an SD card with a copy of all of my music with the following folder structure: artist/album/song. This is being using in an S4 B9.
The MMI sees the SD card and plays back all my music perfectly but What’s irking me is that after playback of a folder has done, it just repeats that Same folder instead of moving on to the next folder. Is there anyway of changing this? The old RNS510 I had in my Golf was able to do this and I really liked it.
Looking at potential doing a fair bit of travel with work in the near future, about 12k per annum, maybe 15 with personal.
Im coming up to 2 years of driving. My current premium is £650 a year with a Fiesta 1L, which I love to bits, but for long journeys it’s a bit bland inside (gadgets and sound wise). Driving wise, it’s phenomenal, albeit lacking in power a little.
I like the look of many Audi’s, but unsure which engines are any good - I’m less familiar with them than BMWs.
Which vehicle and engine combo, up to 16k ish would be suitable for:
Fun to drive
Bit of oomph
Reasonable on insurance for a 25 year old with 2 years no claims
Well equipped (B&O necessary)
I personally like the look of the A3 saloon, but don’t know much about the engines.
I would the newer 2.0 TFSI engines are excellent (230ps version etc) in say, the last five years.
Some bargains on mk3 TT coupe / soft tops nowadays. I am incredibly biased towards them but I just can't think of a better car considering the blend between performance, tech and its surprisingly practical. A3 saloons are nice enough but I can't help feel driving one would feel a bit bland unless it was the S3/RS3 variant.
Example of a decent spec TT.
https://www.autotrader.co.uk/classified/advert/202007301898684?postcode=cv130bz&advertising-location=at_cars&make=AUDI&model=TT&sort=price-asc&price-from=15000&fuel-type=Petrol&onesearchad=New&onesearchad=Nearly New&onesearchad=Used&radius=1500&page=5
That sub menu allows you to turn repeat off, or set it to folder or song. Took me a while to find that buried away as it was annoying me too. Folder repeat must be the default setting.
Ah apologies, thought B9 was the previous model, not the current model.I can’t find this option anywhere in the menu. You sure this is for a B9? When I press the Bottom left “Control” button the only options I get are to change the source/view. There isn’t anything labelled RPT
