Thanks for providing info on this - its a board I'm considering for my new post-production rig. I will be getting an RTX 3080 when its released, and the rig will have 2 Gen4 NVME drives, maybe 3TB total. I may want to add a third Gen4 NVME at some point. In my situation does the Asus X570 WS Pro-Ace have any advantages over a standard board? I am also considering the Gigabyte X570 Auros Extreme as I really like the passively cooled chipset.
The board layout is what make it appealing, as it has the ability to use the PCI-E lanes in a much more intelligent way. No one in the public domain currently knows if Nvidia will allow the 3xxx series cards to run on PCI-E 4.0, and how it will work if they do, but I'd imagine it will still be a full 16x 3.0 card, depending on your application, the GPU can happily run at 8.0x speeds with little to no loss in performance, which means you'd have the rest of the lanes free for other devices e.g. the M.2 drives.
It's a very well made board either way, and does a great job at doing what it is designed to do - namely being stable for workstation use. I'd probably look at your overall total budget, and decide what can be moved in or swapped around if required. You should make a dedicated thread with your requirements in there, and you could gather some options and opinions, dedicated to your task/build.
