Purchased this a couple of days a go :)
Love the strap.
Two Qs:
Can you basically put the holes anywhere you want? (it looks that way)
Do you know if it would fit a 19mm watch as I can only find it in 20mm.
Thanks
Yeah, hole can be anywhere although I try and get it as centred as possible.
I have the 22mm version and flat, the strap is quite rigid. It might not have the flexibility for that 1mm difference. I'll let someone else with more experience chime in.
Nice TV - I have the E65.
You would probably get more sound stage and Atmos effect from the sound bar if you move it out of the corner(IMHO).
To be honest the plan was to wait until November for the TV/Soundbar setup, but I could not wait and so got them now, I own another property which I plan on moving into Nov-Dec and this room will be a better setup, still a corner but just works better.
