Help
16 Aug 2009
Hiya all am getting no signal l, all I did was put a USB stick in the 3.0 port then all of a sudden am getting no signal error any ideas. I've checked the on board gfx and getting the same. Iv3 unplugged the card and tested onboard but getting same error. Also tested on another monitor
Shine a torch/your phone in the USB port
Look for bent/touching pins
If it's front USB ports disconnect them
From the motherboard and see if it works
I can't get on to check with cpuz
BcVQv6z
Couldn't say what psu, I got a overvlocked bundled cpu was i7 6700 @4.5. 16gig ran ddr4 gfx 1060 6gb. I've had to take the pc to a local shop. When it comes back how would I check if I have a save in bios
The bios will have a profile section
Where you can save or load profiles
But be prepared that your profile may be
Lost
Depends on what they have to do to fix it
