Yes, but I was trying to navigate the folder system!
Exactly!
Well thats your fault then. As much as I am anti-touchscreen.
The modern equivelant of shuffling CD's in the glovebox! Haha
Exactly!
Careful, Jag-man will have an anneurism if we keep on!![]()
. Keep on what exactly? The Last millennium?Landrover do it better with the configurable dials anyway. Keep on what exactly? The Last millennium?
You can have a mixture of the two...
A lot of the things you mentioned come under "set and forget settings" like I said.
Cameras can go in there too because you only use them when parking etc. And the camera screen can automatically come on when you put it in reverse etc.
Bless ACME industries has a single camera![]()
Hello?
I said the camera screen, as in the camera interface. Unless there are 17 seperate screens for all the top down 3d seeing round corners periscopic night vision heat sensing 300fps HDR spy cameras?
If all cars have that stuff soon, people will be forgetting how to drive in no time.![]()
The most common and important things on stalks. Like wiper intensity, for example.what’s the half way house then?
I quite like mcdonalds touch screens
