- 1 Jun 2014
So how many of you will upgrade a 3700x to a 4000 CPU?
Maybe. I'll wait for benchmarks and if there's a decent boost, yeah, probably. If not, I'll wait for AM5 and do a new system.
So you've basically just said you're not buying Zen 3. You know full well 8c/16t Zen 3 won't be £200.but if they want a lot more than £200 for it will just find something else to do with my time.
Who knows. Perhaps AMD will increase the core count in the mid-range segment?So you've basically just said you're not buying Zen 3. You know full well 8c/16t Zen 3 won't be £200.
Coming from a 2500k my plan is to go 8c/16t Zen3 ... but if they want a lot more than £200 for it will just find something else to do with my time.
(In before @jigger says they should be £400+ and worth every penny)
Hopefully the existence of next gen consoles with 8c/16t CPUs will push that price down.You do realise it's £200 for six cores and £320 for 8 cores right?
Or before 4k8k says 16 core should be £200.(In before @jigger says they should be £400+ and worth every penny)
I'm not being totally unreasonable I don't think, asking for 8c/16t to be the new mid-range.Or before 4k8k says 16 core should be £200.![]()
Well in that case I'll ride out 2021 with a 2500k and a PS5I do see AMD shifting the core counts for Zen 4, actually. They said from the start of Ryzen they want to push the core counts up, but I think there were more important things to address with Zen 3 and the chiplet concept than crank the cores up.
8c/16t x600 CPUs with Zen 4-based Ryzen, I'll put a fiver on it![]()
No it’s not unreasonable at all although I think it’ll depend on what Intel bring to the table.I'm not being totally unreasonable I don't think, asking for 8c/16t to be the new mid-range.
I sometimes get the impression people who post here are sleeping on mattresses stuffed with £50s
e: What makes it weird for me is that the same people praise AMD for making 6-core the new mid-range, and lambast Intel for only ever offering 4core.
Then they react angrily to the idea that 8c could be the new mid-range, because that would be "too good" for us or something.
Maybe 6 core needs to be mid-range for the next 10 years then we can move on?
I guess we've given up expecting a little progress without massive price inflation to go with it.
I would say that the generational leaps had been too slow,
That's 9 years of elapsed time btw. 9 years.I think you'll find each ryzen core is significantly more capable than the ones in your 2500k too.
Given inflation, that £120 is about £150 quid today, which is almost ryzen 3600 money. The single-core performance is about 30% higher AFAICT, plus you get two more cores and 8 more threads. Seems like pretty good amount of progress to me...
Are you a semiconductor expert and chip designer? Raw speed gains of the sorts we saw in the 90s and 00s are a thing of the past. Physics gets in the way.
Your expectations are unrealistic. There is no 'normal' generational progression.
2 extra cores and +30% per core in 9 years? If this was the GPU forum you'd be laughed out of the building![]()
As with GPUs, when you can get a whole system for £400-£500 (console), and a CPU + mobo of equivalent spec is £450+ for just two components...
Well it's hard to justify the latter unless you own your own bank.
Would be nice to see a bit of progress. Ie 8c replacing 6c in the mid-range.
You should have bought that 3600 for £140. Shame it was only available in your head![]()
