Desk has changed a lot recently as well. I've decided to go quite minimalist and just use a laptop. Currently using my work laptop until September then I will likely get a Macbook Pro. Painted the back wall and plan to add a frame in the centre of the wall.
Desperately need an office chair but haven't decided on which one yet.
@fobose cheers, I did try that but the pic wasn't showing. Turns out I just needed .jpg on the end! Thanks!
Nice looking desk surface - what's the make?
You change setup more than I do pants, and that's daily!
Zero tidying, after a night shift:
I'm especially proud of my Blue Yeti Ketchup holder, I discovered this at around 4am![]()
How much did you guys pay for you 'ikea mock up desk' the storage units and the worktops? I'm looking at doing the same thing, how did you go about adjusting the heights if needed, are they supplied with rubber to stop the top slipping?
Also what thickness were the worktops you went for?
Just spotted the Colmans and what appears to be... Salad Cream? Squeezy Mayo? in the beer fridge. So many questions...
Yep, I'm a condiment and beer addict![]()
Nice, OCUK admin username and passwords in your notes.![]()
fibber, the password I use here isn't written anywhere. All the sticky notes are all air gapped stuff anyway![]()
he he it's a tight squeeze in the corner though.![]()
Weird question. What is the average height from floor to bottom of desk for you guys?
Ive just made a terrible mistake and taken too much off the legs as I thought mine was too high. It was 77cm now its 69cm (oo, er, missus). Now everytime I try and cross my legs I bang my knee on the bottom of the desk.
Should I raise it more or just stop trying to cross my legs?
0.821mm? How short are you???Best of a bad situation, my new born daughter got my old office (spare room) as a nursery so I get the 'utility room', better than nothing, but you are right I can't straighten both my arms width wise, not even close
Mine is 0.821m, which allows for plenty of metrosexual leg crossing![]()
Oh metres not mill.
