50kg, that’s a fair weight for a bench and it seems to have good feet placement too. Mine is definitely lighter than that (closer to 30kg I think), but doesn’t have all the moving bits, so that probably lightens it too. Is it flat/incline only or can it do decline too?
Good thing you found out now that you had some loose bolts. I need to check mine actually, although they were on pretty solid originally!
My 25kg plates have dispatched, so they should arrive before I start back in work. Means I can work toward pushing toward and beyond my prelockdown lifts - also act as additional rack support in case I need to bale, not that I have for years.
Im around about 85.5-86.5kg, so not far off my prelockdown 88kg. Just need more of that strength back.
Friday looks gusty. My gym has passed the rain test, now it’s going to get a gale force storm test, probably while I’m deadlifting. My dehumidifier insulation pipe arrived today, so I’ll set that up tomorrow.
