You picked the Overclocked 7700K result, not the stock version which is beaten by the stock 3300X.As evidenced by the 3300X
The 3300X only has 1 CCX, there is 0 Intercore latency, the result of that is this 4 core 8 thread Zen 2 CPU at 4.4Ghz is with in 3% as fast as a 4 core 8 thread 7700K at 5.1Ghz, the clock speed difference between 4.4Ghz and 5.1Ghz is 16%, so the IPC difference is +13% to the 3300X. (186 vs 193 FPS)
The 3100 is exactly the same as the 3300X, the ONLY difference is the 3100 takes its 4 cores from 2 CCX's, like all other Zen 2 CPU's, at the same clock speed it gets 162 FPS, the 3300X at the same clock speed is 14% faster.
In multi CCX versions Zen 2 has about 97% the IPC of Skylake in games, with a single CCX Zen 2 is about 113% of Skylake in games, in productivity workload Zen 2 in any form is... no surprise about 113% of Skylake. Skylake BTW is the same IPC as all its successors.
There likely will be at some point but a X570 will run one no problem. Certain 450 models will support them too.Sorry if this is a repeated question, will there be new boards launching with Zen 3? Not that I need to buy the board now, it will just sit on a shelf but good to do the research in advance
I've been on the Intel side for a while, so the prospect of not having to update your board with every chip is a novelty. Think my last AMD chip was an Athlon 64...
we can't really know what the 7700K is running at stock, we do know its running 5.1Ghz overclocked.The stock value and score is right there on the graph you posted, a few lines below the 3300X. No doubt though if you want to Overclockers the 7700K is probably the better buy but if you’re old like me you don’t bother with that kind of thing. Plug it in, does it work? Great! Let’s play some games!Meh fine...we can't really know what the 7700K is running at stock, we do know its running 5.1Ghz overclocked.
Rumblings of X590 and X599 boards.
An intel 10900k is better for games dispute being slower than a 3900/3950 in overall performance. It’s better because it’s individual cores are faster. This has been the case since Ryzen launched. People buy Ryzen because its good enough and offers better value with its cheaper overall platform costs.
Yes they do, despite their differences to things like IO and memory, the cores from the same family (e.g. Skylake) have the same underlying architecture and are directly comparable.
Which ever way you look at it, a processor with less cores but clocks higher is faster in games and always has been (bar the odd exception).
The best Zen 4000 processor for gaming will be which ever one clocks the fastest, that will likely be the 8 or 12 core version when it launches. The 16 core will be slower at games because of its slower clock speed.
Wonder when people will shut up about the sodding fan.Wonder if the X590/X599 will have a constantly running chipset fan?
Haha, LOL...
Mine doesn't run all that often AFAICT, but I did end up changing motherboard to an MSI because the fan placement on MSI (and gigabyte IIRC) is a bit further away than the placement on ASRock boards. ASRock chipset fans effectively just pull in hot air straight from the graphics card. If you have a honking great graphics card...
"The X570 chipset is most likely the consumer offering making the X590 chipset the higher-end part."
I always thought X570 was pitched as enthusiast level. Wonder if the X590/X599 will have a constantly running chipset fan?
A bazillion retimers just to get PCIe 4 signalling across the board and a Zen 2 I/O die backported to 16nm to act as the PCH because Asmedia were late? Yeah, I'd definitely say X570 was a rush job.X570 I always considered a stopgap rush bodge.
ARMedia suck. a lot of early Zen issues were Chipset.
