That doesn't really help. Are we talking new or used?
If new, the 3 series is a better car. If used, it depends on the age. The 2017-19 X3 is much better than the 2012-19 3 series for example.
What happened with the chains, you never heard of the old e46, e39 or e90 engines ever having problems with chains so it’s not like they didn’t know how to build them correctly.
The only issue with chains were the chain guides on an e39 m5 that I can think of.
Sorry, me again. Does a pre-LCI F10/11 with xenons indicate that it has the vis pack?
No, you can get xenons without the visibility package. It's rare, most do have the pack, but it does happen.
All LCI cars have xenon lights as standard.
Im not sure it makes much difference anyway, high beam assist I've found pretty useless and the adaptive headlights are underwhelming pre-LCI.
Interesting. What don't you like about high beam assist, is it slow to react? I'm not specifically looking for a car with the vis pack but it's nice to be able to tell if a car has it or not.
Are there any other signs that the car has the vis pack? I think I've read that LED front indicators are included?
High beam assistant on the pre LCI cars isn't brilliant. However on the LCI cars it is absolutely amazing as it does proper matrix style beam splitting.
Am I right in thinking that the vis pack is very rare on the LCI cars? I think I can quote you when I say that many people didn't feel the need to upgrade to the LED headlights?
Usually your tax liability on the sacrifice amount is replaced by company car tax.
Which is why do many people are going Tesla.
Now I've finally started at the new place and got the full details I do pay tax and NI on the amount but the way the scheme works it is more efficient to use the system to take the car than to take the cash. I've been playing for a few days with various options and the M340i through the scheme is bloody expensive as are the S4 and c43...but oddly the RS4 isn't so I just ordered one of those instead
