The problem with the higher mileage one is that you can't get a fully comprehensive warranty on it anymore...only driveline, and it will be an expensive warranty too.Probably one for Foxy here.
Looking at changing my 3 series for a 530D GT.
I have seen a couple around a similar price, but one is newer with higher mileage on it.
Both are well spaced, but the higher mileage one (101k) has the HUD as well.
Couple of questions:-
Would the high mileage be a put off on one of these, or would it be better to get a slightly older model with less mileage?
Anything major that I should look out for? I have heard that the rear suspension units are expensive to replace, but it appears that the engine is somewhat bombproof if serviced correctly?
Cheers
Test driving a M340i on Friday. Rather excited.
I hope it's an unaccompanied one...
surely one benefit of Covid?!
You can still do both of those things with the sales guy in the backLet's hope soI have a feeling that the sales guy will sit in the back. I don't intend to powerslide it, but it's nice not to have to talk the whole time and you can choose your own route.
I think you'll enjoy itTest driving a M340i on Friday. Rather excited.
I think you'll enjoy it![]()
MaybeAre you getting one on the 1st?
I had a loan of one this morning and it was chucking it down, it has a lot of rear bias on the x drive system took me a little by surprise but the lower level of grip showed just how well it handles and how good the M Sport diff is. If it’s anything to go by the new M3 Touring is going to be superb.
Quick aswell 0-60 in the wet 4.3 seconds using a VBOX, recon it must be good for a sub 4 in the dry.
Sounds really good, thanks! Did you manage to do many miles in it? I'm seeing a few complaints about the seats being uncomfortable with or without lumbar support.
I only managed 50 ish, I’ve done 300-400 miles in another one with lumbar support but all the way in and it was fine.
I don’t generally use lumbar support a lot on cars and not picky with seating position so not the best person to comment.
Seats are fine for me. Done a few 300 mile trips, no drama.
Cheers
