I thought 21st of august for some reason, probably wrong never mind
They're doing the 21 years thing...might be related to that. But it's a 21 day countdown to the 1st September.
It gonna come quick enough can’t wait to see what size of lube I’m gonna buy lol.
Thought you was happy with your 2080Ti. Knew you would want to upgrade. Funny how it works at these times when a new gen of cards come out. Suddenly the 2080Ti becomes a mid range card or certainly a hell of a lot less desirable anywaysIt gonna come quick enough can’t wait to see what size of lube I’m gonna buy lol.
Looks like there's going to be a last minute scramble to keep it cool for AIBs. Interesting times although can't imagine much if any availability 1st Sept.It appears memory is a real problem for Ampere:
https://www.igorslab.de/en/nvidia-a...elf-the-board-partners-are-still-in-the-dark/
It's consuming a ton of power and is clocked to the very edge! I wonder if Micron screwed up??
NVIDIA CEO: Our GPUs are Twice as Efficient as AMD’s Regardless of the Process Node
I like this commentIt appears memory is a real problem for Ampere:
Jenson probably found out that RDNA2 didn't scale well at a family get together when Lisa was a little bit tipsyHow the #### would he know that? RDNA2 isn't out yet, you know what? Lets see how big a liar he is, i'm expecting Ampere to be 2X the performance per watt of RDNA2.
https://www.hardwaretimes.com/nvidi...cient-as-amds-regardless-of-the-process-node/
And the George Foreman GrillNot something I would risk saying if true. But you can bet your bottom dollar that if they screw up and its a noisy heat fest the GIFs are out from the 290x era for sure!![]()
.Jenson probably found out that RDNA2 didn't scale well at a family get together when Lisa was a little bit tipsy![]()
Self, self, selfI think the 3070 will be just gddr6 so won't be an issue for me![]()
I like this comment
"There are no final performance data yet, Nvidia keeps the ball extremely flat for fear of leaks and the AICs even on the shortest dog leash I have ever seen at a launch." Also known as Tom Bradying
Isn't it more to do with the board design, memory on both sides creating a high concentration of heat?
They're both doing really well keeping leaks plugged. I'm actually impressed in this day and age as it can't be easy. X-rays and full cavity searches on exiting the buildingFirst bit of decent potential competition they've had in a while has got them paranoid AF![]()
