- 20 Aug 2020
in my opinion 4 noctua nf-a12x15 2 on the top 2 on the bottom 1 nf-a12x25 on the fuma 2 flipped
This case I'm still mainly tempted for vented side panel with AIO. That will allow great cooling, but I will be missing out of TG panel with RGB.
The Lian-Li TU150 I'd most likely also go for the vented panel version and not the TG panel version. That will be good with air cooling and GPU heat can come out at the side.
Then the Lian-Li O11D "mini" will be best for cooling and RGB, but as we said, it will be bigger by quite a bit probably.
Choices! At least the hardware that will go in it isn't here yet, so no need to rush it, as much as I want to buy it already
I may get the Lian-Li O11D mini to put my current hardware in (as it will fit ATX) and get the Cooler Master N200(P) for the new build.
@McPhee Thanks for your input. The TU150 does look to have a better intake for airflow coming from the front. As you can see in aabbcc's case (no phun intended) with the GPU being that big, it blocks the intake airflow. In regards to O11D mini, I know, but it's so pretty
@aabbcc Have you tried the CPU cooling with the fans turned around? So it has fresh intake from the rear to front? As you said yourself, it looks like the GPU is blocking fresh intake now, hence I'm curious whether the temps would be better that way around.
Any custom loops in these yet?
help me guys
should I buy the fuma 2 and flip it and install noctua nf-a12x25
or
buy arctic freezer liquid ii 240
all are available in my country
I have the p version
ryzen 7 3700x (not purchased yet) not sure about oc since i heard ryzen won't favour much from itwhat processor do you have? what are you doing with you pc (overclock? 3D work? only gaming?)
to be honest yes!fuma 2 will be more than enough then.
don't you want to wait for the Ryzen 4000 series?
Wait, what? The two fans on the air cooler air blowing air at each other? That does not sound efficient at all.Sry was a bit tired when posting, the rear cpu fan is set as intake while the front (right) CPU fan is set as exhaust!
that's my planProbably easier to explain with an imageThis is how it's set up:
140mm fan on vented side panel without the bracket works:
https://imgur.com/gallery/a76Bz5Y
Just a PSA for NR200 builders and potential builders you can add a side fan to the NR200 even without the side fan bracket. I am using a NHU12A to cool my CPU so the included fan bracket doesnt fit, I first tried to screw a 120mm fan to the side panel itself but the holes of the fan and the panel did not line up but with a 140mm fan they line up perfect. Using black screws you cant even notice the screws from afar.
sir you are truly a genius!140mm fan on vented side panel without the bracket works:
From /r/SFFPC
