I can see some vertical boards snapping if not secured tightlyI can see some lesser quality cases buckling under the weight!
Wont need haribo mate he's putting the gel in the box instead for nvidia sales...
Yea, I love all 3 slots tooI love 3 slot cards!!!
It does look suspicious. In the top pic the card looks totally flat but I/O bracket is at a weird and quite extreme angle. It also doesn't look like the cards have been pictured together.Looks a bit suspicious to me. The one picture of the backplate side, shows it all covered up, bar the one fan. Then the other side, you can clearly see through the heat sink to the desk below, at the top bit. If the back plate is as its shown, you shouldn't be able to see the table beneath.
Hopefully that made sense!
3060 400
3070 600
3080 800
3090 1400
Wont fit in many cases![]()
