Don't think there will be a 3080 Ti.
I think we may see a 3090 Ti using the full fat GA102 chip.
The Titan may be on GA100 which will allow the above to happen.
So you think the 3090 will be less than 7552 Shaders?
So the 3090 will be a huge price jump that isn't worth it to most for given performance, we'll see soon enoughI think you've answered your own question, there![]()
From what I have seen even GA100 doesn't have over 7,000 cuda cores.
i said this ages ago there will be no 2080TI + 80%, some even said 2080TI + 100%
I mean colours wise, can people tell the difference between 8bit+FRC/dithering and 10bit?422 has blurry text for one
I've done tests and I honestly can't see a difference.
@Kaapstad
This is Apparently GA102, its on TSMC 7nm, not Samsung 8nm. https://www.techpowerup.com/gpu-specs/nvidia-ga102.g930#:~:text=NVIDIA's GA102 GPU uses the,mapping units and 96 ROPs
It has 7552 Shaders.
There is also this: https://www.techpowerup.com/gpu-specs/geforce-rtx-3080-ti.c3581#:~:text=Unlike the fully unlocked GeForce,mapping units, and 96 ROPs
Apparent 3080TI, 5120 Shaders, also TSMC 7nm, if true it goes against the rumour that everything but the Titan cards are on Samsung 8nm
Right, because even on TSMC 7nm GA102 is already 627mm2. i said this ages ago there will be no 2080TI + 80%, some even said 2080TI + 100%, even Nvidia are not making the die paving slabs as big as they would need to be for that. BTW GA102 is a 400+ Watt GPU.
I'm building a new computer soon to replace my 10 year old rig, so everything is being replaced apart from my SSDs and HDDs...
If I were to spend £500 on a graphics card when the new cards come out, how much of an improvement in performance should they be over spending £500 on a graphics card out today in this current generation?
Just interested in how much performance these new cards are going to have.
My guess from current rumours...I'm building a new computer soon to replace my 10 year old rig, so everything is being replaced apart from my SSDs and HDDs...
I’d be hoping for 40%
Nvidia:
2080TI + 50% (3090) £1500
2080TI + 20% (3080TI) £1000
2080TI ~/~ (3080) £700
2080S ~/~ (3070) £550
2070S ~/~ (3060 £400
IMO AMD's top card will be 2080TI + 30% £900.
For £450 you'll get 2070S.
Nvidia:
I think TPU have their figures messed up.
GA100 is a much bigger chip.
AMD has no ray tracing which FS2020 utilises though.
