- 26 Oct 2013
- Scotland
64CU seems conservative being that Mi100 card has a rumoured 120. I don't think it'll be that high but 80 or maybe even 96 seems potentially feasible.
Yeah, the 5700XT is a middle of development GPU, half old GCN, half new RDNA, its the GCN part thats holding it back from scaling, GCN is horrible for scaling.... they pushed it out half finished mid development because its all the had to stay relevant with Turing strutting its mighty stuff.
Despite this it shows so much promise, with 40 CU's its as fast or faster than a 60 CU Radeon VII at the same clock speed, and the Radeon VII has about double the memory bandwidth.
Its a glimpse of what's coming once all the GCN crap has been ripped out, the IPC is at least on par with Turing, the XBox Series X proves they have scaled it to at least 52 CU's, it has a very clever and capable way of dealing with Ray Tracing, the PS5 proves it clocks to at least 2.3Ghz.
Whats more that XBox is a 330mm2 die which includes a Ryzen 3700X and a total package power of 170 Watt's, take out 40 / 50 Watt's and 80mm2 for the CPU, what are you left with for this 52 CU <2080TI RDNA2 GPU? 2500mm2 and about 120 to 130 Watt's
(Speculation) RDNA2, 64 CU's, 2.3Ghz, a small 10% bump in IPC.... that's a monster, one that should worry the Leather Jacket tho i still think Nvidia WIL WIN. but Jens will sweat buckets to get the win and not by all that much.
That's my prediction.
The difference there though is that these are all generally heavily overclocked AIB cards, hence the larger coolers but the 3090 we've seen pictured is the bog standard FE version.
How big would the AIB coolers have to be on this card if they were able to create KP versions or similar? It's already massive, so I dread to think how big they would have to go![]()
Nvidia were always going to throw everything at Ampere to ensure it won at all costs. If Nvidia retain the performance crown, what will be the cost for their approach of 'stop at nothing' to win.
If they beat AMD by 20% but use 80% more power, that's not a good look for a GPU company that previously boasted hard about their efficiency.
I prefer to just stick with things that don't seem outlandish..![]()
Maybe Samsung 8nm is a hot piece of sh.t that requires such a massive cooling.I still suspect the RTX3090 is a dual GPU or has another chip which needs cooling. The size increase over the leaked RTX3080 cards is noticeable.
My very rough measurements/scaling put it at around 135 high and 335 long, which as you say isn't any higher than current "big" cards but is one of the longest I've ever seen.
RTX?
This is going to end up as a relative planet size meme, e.g.:
Well I just had a result. Went to check on my GPU fund and discovered £400 I’d squirrelled away two years ago.
Should make a purchase slightly less painful.
Current Zotac card is 320mm long. Could see some AIB’s being up to 400mm at this rate. Or will the triple slot design make that unnecessary?
Suppose it depends how good the FE is. That rumoured $150 cooler could be as good if not better than AIB designs so AIB cards may not need to be much more sophisticated.
What's the opportunity cost of that £400?Well I just had a result. Went to check on my GPU fund and discovered £400 I’d squirrelled away two years ago.
It's not single fan, mate. Well, not the 3080 at least. It has one in the "back plate " side too. Looks like dual 92, 100 or what not.
