Huh? They are sposed to and rtx might not come to fs2020 for a whileAMD has no ray tracing which FS2020 utilises though.
Got to leave some headroom for the 3060 Super and 3070 Super in 8 months time, thoGoing to 7nm should be a big step.
I’d be very surprised if something like a 3060/3070 doesn’t match 2080Ti
Erm, if it was round before you stretched it and not round after you stretched it, it's because you only stretched it along one axis
The dodgy manipulation is possibly yours![]()
@Kaapstad
This is Apparently GA102, its on TSMC 7nm, not Samsung 8nm. https://www.techpowerup.com/gpu-specs/nvidia-ga102.g930#:~:text=NVIDIA's GA102 GPU uses the,mapping units and 96 ROPs
It has 7552 Shaders.
There is also this: https://www.techpowerup.com/gpu-specs/geforce-rtx-3080-ti.c3581#:~:text=Unlike the fully unlocked GeForce,mapping units, and 96 ROPs
Apparent 3080TI, 5120 Shaders, also TSMC 7nm, if true it goes against the rumour that everything but the Titan cards are on Samsung 8nm
Right, because even on TSMC 7nm GA102 is already 627mm2. i said this ages ago there will be no 2080TI + 80%, some even said 2080TI + 100%, even Nvidia are not making the die paving slabs as big as they would need to be for that. BTW GA102 is a 400+ Watt GPU.
) where it says GA102 Notes - Speculation. TPU don't know the specs so the number of shaders may not be 7552 but more like the number in the leaks from rogame etc, ie 5120 (3080) and 5376 (3090).I didn't see that but am well aware this is all speculation, which is why i said "apparently".@humbug you haven't seen the notes at the bottom of those specs (or you've chosen to ignore it) where it says GA102 Notes - Speculation. TPU don't know the specs so the number of shaders may not be 7552 but more like the number in the leaks from rogame etc, ie 5120 (3080) and 5376 (3090).
Why did you stretch it along only one axis tho?Yes it was round before i stretched it, but I had to stretch it to correctly proportion the PCI connectors on the bottom and the metal bracket on the left. So it was out of proportion before but with round fans, and making it into proportion made the fans not round.
Really hope this fits in my mid sized case. I am already upgrading my PSU for the 3090. Really don’t want to move everything to a new case.
If the 3090 is about 20% or so quicker than the 3080 then for sure the 3080 will be the best for the money, if those prices were accurate anyway
I do think doubling 2080TI performance is fantasy, just like i think doubling 5700XT performance on the AMD side is fantasy, i do however think people underestimate what AMD could do, because they haven't looked at the 5700XT critically, its a seriously quick card for what it is and its easy to scale it up and see what something like that could do scaled up.
Its an RX 580 replacement but punching way above that level.
Glad I'm using an open bench case for my 24/7 PC, it can take any size card.
I'm not going to post it all again but the shoulder height looks the same as a Kingpin, or any other big card. So the card looks like it is 140mm high or so. The length? I really cba putting it into Photoshop and peeing around but I could work it out. I think it is going to be over 300mm long, maybe like the 6990 which was 310 or so.
No idea why anyone thinks the pictures couldn't be legit, its a perfectly 'normal' size fro a very powerful GPU.
Fans? possibly 100mm, or if it really is that big? 120. I reckon 100, though. Just like all of the other enormous cards on the market.
I don't think it will be awfully bigger than that (the 1080Ti KP) but if real it's deffo 2.5 slots thick. So over 50mm, hence the triple back plate.
What was the reason for not maintaining the aspect ratio?
RTX?first image of the Ampere GTX Titan
RTX?
This is going to end up as a relative planet size meme, e.g.:
In true AMD style, the Navi 10 design was borked by all accounts meaning they couldn't scale it up and didn't have the time to fix it, hence the 5700XT was fed steroids to take it way beyond its original position in the stack and left AMD with nothing else to fill out the other tiers. At least until much later and lower.
I just hope they learned those lessons, fixed their future designs so they wouldn't come back to haunt them, giving us a proper release of RDNA2 without any dramas.
