Caporegime
- 9 Nov 2009
- Planet Earth
The RTX3090 is 310MM long and uses a 2.75 slot cooler:
Its not the cost that would worry most. It's the potential shift in direction from efficiency and performance per watt to raw power.Not sure why anyone worried about a min 850watt PSU
The price of this card going most likely cost well over 1k
A 850watt PSU costs about £120 (Got be one of the cheapest parts of a high end PC build)
I measured my available space today just in case i get a new case.The RTX3090 is 310MM long and uses a 2.75 slot cooler:
I've got 370mm to play with, oo err.
So, I've got the psu and the space.
But will i be willing to spend the money for it![]()
Anyone care to hazard a guess on the price of the 3070?
Will it be more powerful than a 2080Ti?Same as the 2070 was, $599
I’m just after something that will steadily run FS2020 at 60fps, ultra detail at 1440p, over the entire world. No dips in cities.Nobody knows anything much yet. The models they're going to release are still rumour and speculation, performance figures a load of guesswork.
Nvidia are going to make some sort of announcement a week on Monday (1st), and we'll get some better ideas then. But we won't really *know* anything until performance reviews start to hit a while after that.
Whoah slow down man. It is "recommended" that you use a 850w PSU. Just like when Nvidia recommended a 750w PSU for the GTX 480. It doesn't mean you need one. Well, let's face it any one who knows about how PSUs work know it's not a good idea to pull more than 50% of the PSUs power (for efficiency heat and noise) but many would get away with a 650w on this if they had the connectors for it.
However. Do bear in mind that this is about the 3080. Not the 3090. That could be a whole different animal.
Too big for my case.
.I've got a coolermaster cosmos s from around 10 years ago, it's a beast of a case and has a220mm? Side fan.A lot of it is width as well. As some cases will suffer if the card is too close to the window for example. Especially if it vents heat mainly out the side like the ftw3 2080Ti. Found this out on my old lian-li dynamic as it was about 10mm off the glass.
One reason i went back to my trusty old 900D. Will fit anything.
However reference cards are usually base pcie size i.e level with the bracket. I will be suprised if it is as big width wise as the leaks suggest. A lot of server systems etc have this in mind and may not fit cards of that size so would be an odd route for nvidia to take in my opinion
I am sure if you can spare £1400 for a card another £200 for a case is no problem.
Oh and potentially another £150 for a power supply.
