- 18 May 2010
I think this is currently one of my favourite builds. Cryorig H7 Quad Lumi both vented and TG panels showing.
https://www.reddit.com/r/sffpc/comments/ibx5wn/nr200p_nr200_rgb_build/
Vented has better temps, but 70C with TG isnt that bad.
Edit: Just saw that Cryorig uses NZXT CAM software, so I won't be using that after all.
Annoying isn't it, was very close to buying one and then read you need CAM to control the RGB, no chance I want that bloat on my system
Impossible to find at the moment anyway
