New chain fitted. Jumping sometimes, seems to be multiple gears though generally always middle of block ish. When it jumps it falls off outer chainring almost onto inner. Chainring or still possibly cassette?
I was for sure a bit overdue on the chain (didn't seem to last as long as usual and had been lax on checking!).
Edit: Wow, it was only last March I got the chainring... so ~6-7k miles ago.
Okay so I found pics of the chainring from last year.. new..
and now...
Ouch. I know winter was tough but the previous chainring lasted 3-4 years (new with bike) and many more miles before I had any issues. The small chainring was replaced after a few years and looks fine still. 105 = cheese?
I tried it a few years ago and think I actually made them worse. My front wheel needs done but the shops here are all booked up for two months due to the government voucher so I'm having to live with it.Anyone has any luck learning to true their own wheels? Just conscious that our local bike shop won't be able to fix for 2-3 weeks!
Yeah that is a bit ******.
I've had to change an ultegra one last week that looked better than yours and wouldn't slip if going up a hill in a high gear low cadence sort of power but would slip off sprinting out a corner more high rpm type torque.
Generally cassette slip you stay in gear and get a bang. Chain rings the outer slips off fully or into the inner and a worn inner usually shows up as chain suck up and into the frame if really bad or a rumble as it holds onto each link ever so slightly. You'll look down and see the chain bouncing around under load.
We're booked out for at least a month but still faking in punctures and wheel truing as they're kind of essential.
The theory isn't hard and you can get it relatively good using the brake pads. Find which side the buckle is, move the caliper so the pad is touching only at that point and adjust the spokes on the opposite side of the wheel a quarter turn at a time.
That's a nice looking pump, what model is it?
Just make sure the hose isn’t going to rattle and rub your paint/frame away!
So I got this new High Pressure, mini track pump this week -
First trip out with it, someone got a flat. People had been interested in the pump, so I was called to action! Have to say, I'm really impressed by it. Obviously not a patch on a proper track pump, but I had the guys tyre to 80psi in probably about 20-30 seconds. I'm even considering seeing if I can fit a second tube in my saddle pack if I remove the Co2...
Anyone got any suggestions for a saddle "upgrade" to my stock specialized one? Its been ok for me so far, but usually a bit hard on anything longer than 30 miles.
As always for me (budget biker) something that wont break my bank.
Saddles are so personal but I love my Fabric Scoops.
