My Focus ST has an oil temperature gauge
Picture froma Focus RS but the Focus ST has the exact same gauges
Does it have an actual oil temperature sensor though? The Mk2 had the same gauge layout but didn't have a temp sensor, it was all "calculated" based on engine load, coolant temp and stuff.
Would a good multigrade oil of the correct spec not be doing a good job from the get go?
Nope, cold oil regardless of grade is still going to be vastly thicker than warm oil
