£799? 5-10% faster than a 2080 Ti
That price/performance may be just enough....to get me to wait and see what AMD's offers.
How can there be such a big difference in memory between the 3090 and 3080?
The 3090 sounds more Titan than 2080ti.
I think unless you #need a new graphics card right now, then you'd be a little crazy not to wait and see. What's the worst case scenario, you let everyone else be the BETA testers if AMD don't bring anything you are interested in?
EDIT: Launch date seems to actually be end of September as well, so no reviews until then.
Guess it depends on the level of need
My worry would be everything goes OOS and pushes prices up even further. Supply and demand and all that![]()
No winks yet form Gibbo.
A wink aint good enough anyway. Why don't people just reveal what they know? What difference does it make? Do it under a different name, send it anonymously to someone, there's no way they could identify who it was.
If I worked for somewhere that had secrets like that I would reveal them somehow, and I wouldn't get caught.
That's what they want you to think. What a bargain this card is at £1500 as it's spec looks more like a Titan which last gen cost £2500. Add in the 90 which suggests this is above a 80ti and Nvidia marketing are off to a flyer.
Even if it comes in at last gen prices for the 2080ti it still looks like you are getting extra because this is a 90 not a bog standard 80ti.
If only it was that simple, you build relationships on trust something you obviously can not be relied on for. Companies also spread false information so if it leaked they know who or where it has come from.
If you're intelligent about it though, you just release what you know for sure to be true. And if you don't know anything robust, then you say so instead of saying nothing. Why not come on and say "yes I do know things but I can't reveal them"? Be honest about things?
Re the trust statement - I think it comes a point where you have to decide what should be a secret and what shouldn't. Its not about betrayal. For example, so what if the release date is public? So what if the date that OCUK is expected to get stock is provided? That doesn't change anything. If there were genuine consequences to revealing the info then fair enough.
Too many secrets in this world.
I have a genuine curiosity about this. If the thermals are well under control, do any of you care what the power draw is?
Anyone else think the TBC at a later date 20Gb 3080 will actually be the Ti?
"The RTX 3080 gets 4352 CUDA cores and 10GB of GDDR6X memory. This card will have a maximum bandwidth of 760 GB/s thanks to a 320-bit bus and 19 Gbps memory speed. This model has a TGP of 320W and the custom models that we saw also require dual 8-pin connectors."
Isn't that pretty much a 2080 Ti, with 1GB less RAM, and a 320-bit bus instead of 352-bit, and 19Gbps speed?
