Caporegime
- 18 Oct 2002
Triple 8 pin, this thing looks a monster! Always liked Zotac cards this might be the one I go for.
A card so big they can only fit it into CAD atm
1933 Boost Clock? 45c temp?? Seems the leaks are coming boys!
Can you translate this pic for laymen like me? Don't have a frame of reference to understand it.
Think I'm settling on the founders edition 3090 if I can get one. Better not be anymore than $1400 -.- you'd hope it would be £1049-1099 with the exchange rate.
Modern GPU's run at higher clock speeds when they are cooler. I have never used that software, but my guess is that 45 degrees is due to a light load...so 45c = boosting pretty high. (1933)
The clocks will most likely be lower at higher temps, and the temps will probably be higher at higher loads.
To conclude from that that the Samsung die is poopo is a bit of a stretch. Poopo compared to what?
Hilarious.
Ah okay thanks. I thought the Firestorm pic was showing some benchmark figures/score, and hence would have been meaningless to me without a comparative score.
Given the focus Nvidia put on the GPU cooler video they released and this somewhat unique design on the founders edition cards, have we got it wrong then in terms of the heat i.e. it doesn't need a fancy new cooler because its so hot, but rather it runs (relatively) cool thanks for the fancy new cooler?
It's generally thought that Samsung 8nm is a bit of a misnomer, and it's closer to a half-node off of 7nm TSMC in terms of advancement. I'm gonna bet that they're producing the 3070 and below on Samsung, and the 2 above on TSMC (initial results must NOT have been good!).
its gonna cost us troops that's for sure 1 tube of lube at the ready lol this one gonna hurt.
hopefully they’re pushing these hard because they know AMD are bringing something to the table.. wishful thinking hat on of course
Just because it's cut down does not mean all disabled cores had defects - it's just transistors can use more power than some more luckier ones, so you can't use all cores at same high frequency even if there were no defects, that's why (I think) power usage isn't that massive between two variants of the same chip.
says TSMC on most/all products.
If there is such a massive variation then again that indicates yield problems though.
Wonder what card the bottom right is. Perhaps the 3070, with the runt card (3060) to the left of it?
