Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Is that so no one can see where you are looking!
I want to be like Neo.
Most modern window glass IIRC blocks enough of the UV to stop it working, especially double glazing.Sunshine via a window doesn't affect it?
Certainly I can't remember mine ever activating due to light when indoors, be it at home or in the likes of a shopping centre with glass walls,
In a car, I've never felt the need to wear sunglasses, so don't mind that they don't go dark
Standard photochromic lenses activate when exposed to UV. Modern windscreens block UV light. Transitions XTRActive lenses darken behind the windscreen of a car because of the unique technology they have, which responds to visible light, as well as UV, to protect your eyes from glare and sunlight while driving.
Quite sad isn't it.To be honest I don't think they do transition that slowly. Takes about 30 seconds when coming indoors, and to be frank if you're making judgement based on somebody having dark glasses for a few seconds after walking indoors, they most certainly aren't the dick in that equation.
If they're "tinting in normal daylight" then there is enough UV light for them to react, which means they're doing their job of protecting your eyes from the UV. It can seem overcast/dull but you can still be getting most of the UV you would on a sunny day, in this instance the transitions are actually better than dedicated sunglasses as they offer the protection when you wouldn't normally think of it (remember you can get sunburned on an overcast day in the summer).Haha I think I touched some nerves with my earlier comments, just my opinion and that’s from someone who was wearing a pair.
Maybe I’ve not seen the right frames just never seen a pair that look decent in both situations (clear/tinted).
Also found they had a habit of tinting in normal daylight when not required, hence looking like the dick with sunglasses on when not needed.
Hey I included myself in the dick description from my own personal experience, and my own personal opinion still stands, just wasn’t expecting anyone to really care/get upset.jeez, you pulled that card? You say people look like a dick, they react and you say you e touched a nerve?![]()
They don't just get dark in the sun though, they also get dark inside too. Or everyone I've seen wear them, they do.
They aren't asthetically pleasing, to me and I'd never wear a pair. (I do wear glasses too).
They also are not 100% dark, I want my sunglasses to be dark enough people can't see my eyes, better still like a mirror. Transition lenses doesn't do that. It constantly sits between the 2, it's like 10% grey to about 70% grey. I personally rather have totally clear and totally dark.
They react to UV light, so if they darken indoors there's a fair bit of UV indoors. That should only happen in a room with at least fairly large windows that don't block UV.
If your glasses are 100% dark, you wouldn't be able to see through them.
My photochromic lenses get dark enough for people to not be able to see my eyes. Or for me to be able to see in normal lighting.
IIRC they're a specific version not the normal ones.the new ones don't just react to uv .
edit : I was thinking David Brent , or David Soul too, used to wear them ?
