How many games actually support SLI still?
you would also need to upgrade to PCIe gen 4 as gen 3 X8 will almost certainly be a bottleneck.I play GTA V maxed out at 4K with 4x TXAA, and 2 2080 Tis struggle in areas with grass. This means that a single 3090 might also struggle.
I might go with 2 3090s in SLI, so I can almost guarantee a minimum of 60 FPS in all games at 4K.
As well as a step-down transformer substation at the bottom of your garden.you would also need to upgrade to PCIe gen 4 as gen 3 X8 will almost certainly be a bottleneck.
I would certainly recommend Zen 2 then with an X570 board. Not only for the PCI 4.0 on the GPU but im pretty sure stuff like premiere gets a huge benefit from using faster drives. Such as pci 4.0 nvme drives.. Plus the core/£.
Just my opinion though.
But with Zen 3 not far away I'm wondering whether to wait for that as well.
Intel CPUs beat AMD CPUs for gaming but AMD has PCI gen 4, will this counteract the performance difference..
My bad it was 7800GTX 512mb but the sequence of events regardless of names is real.The ATI x1900 came out before the 8800gtx and the 8800gtx was a beast of a GPU nothing could touch it for ages
I myself went SLI 7800gtx > x1900xt-x > 8800gtx
If two 2080tis can't do that it's not because the cards are bad it's because the engine is ****
That's a good result, here's hoping!Depends from ones point of view. If 3070 hits 2080ti performance with double the RT performance for $499 or less then that is not too bad no?
I've been to Rio de Janiero once. I arrived at night and when I awoke in the morning I looked out the 20th floor hotel window. As I looked down it looked like Crysis I **** you not. That's the first thing that occurred to me.And, just like Crysis, utterly unrepresentative of 90% of games.
I hope something does push you over 60FPS 4K and we get DX12 plus SLI support in MSFS2020. I just can't see 60fps 4K all ultra over NYC in MS FS 2020 from 3090SLI. I want to but I can't.With the sheer brute force of 2 3090s, I don’t think that using PCIe 3 will have a massive impact. Perhaps 5-10 FPS max? Even a 20/30% improvement over 2 2080 Tis is acceptable to me. In fact, anything that pushes me over 60 FPS at 4K will do.
I think you may be cherry-picking the highest prices you can find on the old-card in your example. I just went to the bay that sells used stuff and searched for "1080ti"...found 3 cards under $300 on the first page.
Has anyone seen any 3090 leaks with any listed as 27cm or less? All the ones I’ve seen are huge
