Caporegime
- 18 Oct 2002
If with 52 CU's an XBox Series X matches if not beats a 2080 Super, an 80 CU RDNA2 GPU should compete with a 3080.
Guys the 3080 was vs a standard 2080, the performance difference was 60 - 80% in Nvidia controlled benchmarks, so best case. The 3080 is about 35% faster than the 2080TI.
The 2080TI is 15% faster than the 2080 Super, 80CU's is 55% more than 52. Take the clock speeds from the PS5 as add them to that you get 330Mhz or +18%.
An 80CU RDNA2 dGPU at 2.23Ghz is probably 40% or more faster than a 2080TI, so at least as fast as the 3080.
The 3090 has 25% more shaders, Nvidia have pushed the 3080 pretty close to the top tier card, to in side of 25%, i suspect they did that because they know what's coming.
Damn I'm excited for more info now, hope they start leaking soon!!
I only want an RT-capable card for CP2077, so can afford to wait and compare
