That looks terribleOH MY GOD THAT FAN ON THE TOP OF IT
It makes that Zotac with the extra fans not look so bad
Edit - the Zotac looks equally terrible
Wait until you have all the options at your fingertips, pre-order now, and in a few months time you'll be thinking "Wish i'd waited for x"....
I rather have my 11GB 2080ti over a 8GB 3070....That's a good price to be fair, I don't think 2080ti's will be hitting £350 anytime soon unless the 3070 really does match/beat it in everything.
nice i need to have alook nowWell ive just had look, and ive found 2x, RESULT!
Clowns need the space, they've got big shoesCan we talk about the fact that the clown card is a QUADROUPLE SLOT card!?
Haha it'll be one or the other young Jedi, I'm hoping the Vram on the 3080 will cut it but I have my doubt's and no-one really seems bothered about 10gb being a limiting factor, but it has me worried. But over double the price is quite a pill to swallow for the 3090 especially when NV didn't really talk about it so I doubt it'll be much quicker when the Vram isn't being used.
so what does an £800 3080 AiB get you that a £650 doesn't?
especially given the FE at £650 uses an expensive cooling solution...
Why? its toally different RAM> like DDR3 / DDR4.I rather have my 11GB 2080ti over a 8GB 3070....
Looks like an afterthought. Quick, get an extra fan on there........That top fan looks *awful* and what's with the loose wire!!!???
Ill be going either 3070 or 3080 from V64. Its the first time ive felt the cost to do so is worth it.Anyone going from a Vega 56 or similar performing card to a 3070/3080? My V56 is doing a good job at 1440p but I'm playing slightly older games (Forza 3, the Tomb Raider trilogy), and it might struggle >60/100 FPS with more demanding games. DLSS and a card considerably more powerful than my V56 on a G-SYNC compatible screen sound like a tempting proposition.
What is this IO? No time to watch, so a TL-DR would be sweet thanks
Are they trying to emulate some sort of push pull configuration?Can we talk about the fact that the clown card is a QUADROUPLE SLOT card!?
I think its a last minute addition because the card was obviously getting too hot under testing. Makes me worry about getting any AIB card tbh. but lets see. I've decent case flow. and its going to be winter....Are they trying to emulate some sort of push pull configuration?
Also this is going to cause clearance issues with any RAM modules and CPU coolers :|. What a joke of a design.
I mean vs the 3080TI specs they're already posted here! https://www.techpowerup.com/gpu-specs/geforce-rtx-3080-ti.c3581It has 20% more cudas and more faster memory. As well as more tensor and RTX stuff. So we could be talking 30-40%.
For me it depends how fast it is. As no doubt if I buy a 3080 I’ll get burned and want a 3080Ti when that is released. I’ve had that happen before hense why I went 2080Ti last time .
Quite.2080ti as low as £560 'buy it now' on the bay.
