They been on 7nm a while who knows.If it was actually 160CUs that would be a bit of a 4870 repeat. Surely impossible on 7nm.
AMD cpu's never had driver issues haunting them for years, that's the big problem that stops more people buying radeon cards. Even if their drivers were rock solid it's still something that's been talked about enough to stop people buying amd cards.
Not much to say, it's in-line with other rumours & guesswork. I'm still sad over HBM. For me what's most important is what they do software-wise, AMD generally doesn't fail with the chips themselves. But obviously we won't know anything about that until they actually reveal them.
RDNA1 had double CUs, so it is just a continuation of that design.Interesting.
Does this suggest AMD have doubled up on the CUs as well, like NVidia has done? There are 8 blocks of 20 CUs (2 blocks per shader engine) shown there which is 160 CUs total.
And there are 12 ram boxes could indicate 12 Gb.
For a few years they were great with drivers, right from the November of the year they released the 7970 up until the 5700 release. Sure they had minor slip ups, but no drivers from either company are perfect and there will always be small issues. They were just getting over the stigma of bad drivers when they messed up with the black screens on the Navi 1 cards.
The other problem is that during the times they have had good drivers, they have really messed up launches. Tahiti, Hawaii, Fury, Polaris, Vega.
Hopefully for RDNA 2, the launch will be good and Drivers will be good.
Just to add to this, from the MS hot chips presentation the XSX has 26 active dual CUs or 52 CUs. If this image is true and if it can properly utilise its CUs this will be significantly faster than the XSX.
the XSX has 5Mb L2 Cache, if i am reading this diagram right, this only has 6MB which seems low considering the size difference between the two.
Haha. I was slightly concerned that I may have over teased you with floppy poppyYes, you must know me well enough by now...
Unattainable clock speeds with my early silicon, very unattainable...
You waited this long with that RX 580?
Wait what? Buy that measure this is either 26 dual FP CU's vs 80 dual FP CU's or 52 singular FP CU's vs singular FP 160 CU's.
I can't believe that, because if it is true Navi 21 will crush a 3090, no, i have to believe its Dual FP 52 CU's.
It's not a 4x increase in CUs. Someone already explained it above.
If it was the FLOPs number would also be 4x. But it is only 2x.
It may not be the gaming card, tho i thought that had 128 CU's? in any case i don't know where the blue tab on the right side came from but it looks to be making the same mistake people did with Ampere, the reason Ampere has 2X the TF of what was leaked and rumoured is because no one realized Nvidia are using dual thread cores, each CU has twice the FP units that Turing had. 1 Turing vs 2 Ampere.
This, in RDNA2 is exactly the same thing.
That's 28 Dual, or 56 Singlar Shaders..... *Gulp*
Is it officially 56CUs now or what?
If you are talking about the XSX, it has 56 CUs for yield reasons.Is it officially 56CUs now or what?
You are correct, i shouldn't have been lazy with my response.Thought it was 54 with 2 disabled?
