Is it?Its midnight for the FE isnt it? So stay up and order an FE on the 17th at 12.01 and then order from OCUK at 2pm. Keep the one which arrives first.
You sure?
In that case it's gold.
Isn't the FE card launched on the 14th though? The embargo is lifted on FE that day too
What you think guys. How much % will be faster rtx 3090 than 2080 ti ?
For reviews and maybe pre-order for it as I understand. Would be nice if the case, so they can have it dispatched and delivered for 17/18thIsn't the FE card launched on the 14th though? The embargo is lifted on FE that day too
Do Nvidia think people are stupid to drop £500+ without benchmarks?
Exactly, even if I order, I will not open it before I see benchmarks. If it turns out poop I can just return it and sight false advertisementYes. Not like you can't cancel or return your order after the reviews come through.
Exactly, even if I order, I will not open it before I see benchmarks. If it turns out poop I can just return it and sight false advertisement![]()
Well Chinese miners at it so wont be any stock left for us
https://cdn.wccftech.com/wp-content...e-RTX-3090-GeForce-RTX-3080-Waterblocks_8.jpg
That's not a mining card. It's a fancy waterblock.
https://wccftech.com/bykski-launche...3080-reference-custom-fe-flavor-water-blocks/
Not sure who's sending you this fake news, or are you creating it?
Out of all the cards FE looks the best, haven't heard good things about ordering from Nvidia though
