That thing looks a long way from mass production though. It makes me think it will be a while before we get these on shelves.
On par with 3080 is not enough unless it's half the price. People have gsync monitors.. you need to intice them to change.
Depends how much you value Raytracing etc I suppose. To me, I care nothing for it. I am all about rasterization performance. If AMD can give me a 3080 equivalent for £550-£600, I would jump on it. Especially with more VRAM. But here's hoping they can do even better.
I have had equal amounts of AMD and NVIDIA cards in my lifetime and have had next to no issues with either. Radeon drivers have been solid. I don't mind going with either brand, but AMD typically brings the best value, and this time, may have something a bit special.
Has A0 on it, typically that means Production revision for testing before the A1 release. I suspect its a production sample they're testing in some way.
My last AMD card was the HD 4890. Loved that card but since then I've found AMD to be way behind..
I want to sell my 5700xt while it's worth something
I'm glad they've broken the silence. I'm looking to upgrade my CPU as well as GPU this year so I think I might resist the pull of the Nvidia 3000 series and see what AMD have to offer us.
Only problem is, availability is looking like November at the earliest, but I've waited 3 years to upgrade my GPU so what's another 3 months.![]()
I think AMD are going to dethrone Intel for fastest gaming cpu and take out the 3080. Good vibes.
An AMD based system would completely destroy an Intel one for multi-threaded workloads (video editing, encoding etc) and I only expect that gap to widen with Zen 3
Intel still wins for gaming, just. But I wouldn't expect that to continue if AMD reduce the latency etc.
I hope so. Would love to see Jensen and the nvidia boys squirm![]()
That looks like a prototype board final product does look like ages away...
"Join us on October 8 and October 28 to learn more about the big things on the horizon for PC gaming"consoles has amd hardware in it....there you go
