AMD Navi 23 ‘NVIDIA Killer’ GPU Rumored to Support Hardware Ray Tracing, Coming Next Year
Status
Not open for further replies.
It does sound incredibly hypocritical BUT...there is a difference; Nvidia have always typically managed to produce more efficient cards. If AMD manage to match a 3080 and do it using less power then feel free to mock nVidia but i seriously doubt they will.
What about the gtx480.
Probably like the 2080(S) in newer games it will pull away from the last gen high end while in older games a more mixed story.
It is all about what you do with that power - if AMD comes out with a card that is as fast or faster while using less power then fair game - if a card is using it to sit at the top another story entirely.
Well the cards tends to be built from the point of mainstream games which atm is dx11 based.
dx9 still exist but main is dx11 and some dx12 slowly getting there and as seen with RT, a crawl
All signs atm points to a AMD breaktrough.
So, yea it seems to indicate just that
Is the maths here correct?
IE If:
5700XT gets 100fps (100%)
2080Ti gets 142fps (142%)
Big Navi gets 190 - 230 (190% - 230%)
That would mean:
38 divided by 142 = ~27% faster than the 2080Ti
78 divided by 142 = ~54% faster than the 2080Ti
So wouldnt that (if the 1.9-2.3 times 5700xt is true) make it anywhere between 27-54% faster than the 2080Ti?
Depends on clockspeed now and sustained clocks under load.
I see a lot of speculation and zero information from AMD. What signs?
Point was it's an Nvidia card that wasn't the most efficient.
it was 10 years ago mate. One card every ten years (and that's IF AMD pull something magical)? I'd say that means nvidia typically always had more efficient cards then, no?
IE If:
That would mean:
We are both wrong, to verify.
Big Navi - 1.9X to 2.3X 5700XT: 190 FPS to 230 FPS.
2080TI:
142 FPS + 27% = 180 FPS < Your calculation.
142 FPS + 34% = 190 FPS
142 FPS + 62% = 230 FPS
Ok, I forget the naming schemes, Navi 23 is Big Navi? Navi 21 is a smaller one?
I didn't misquote you, you came across as being committed to nvidia if AMD were even on par then went off track with your car comparison! :p
Fair play you can wait to see before buying, its what Im doing. Dont discount comparisons to older 'yesterdays' cards as its what nvidia are currently doing, and likely what AMD will do on their press info.
Just like this breakdown here:
As a consumer though, it's pointless. I'll be comparing cards that are out now. It's all about what card is better for the price. Not what card is better than the one previous. If amd is the better choice, I'll buy amd. I've nearly always bought amd as I'm tight, and wait out for a bargain deal. As Amd always get good discount/game bundle deals.
2080TI:
Yes i corrected it before your post, i punched the wrong number (132 instead of 142) into my calculator :p
So yes it is ~33.8% - 61.9%
I think realistically, if that rather ropey looking slide is true, it's likely going to be roughly around 3080 performance with the standard variation you get between games. If they have started at "1.9", knowing marketing speak, it is likely more often than not 1.9x faster than the 5700xt with a few games netting a bigger increase.
At least it will have 16gb of vram though, and it will be interesting to see where they price it. They could really take it to Nvidia if they prices it at £500 or less.
Well, i was more basing it on the 1.9-2.3 figure that was being quoted (i did punch the wrong number into the calculator at one point so it should say 33%-62% :p)
Yea suckerpunched yourself, happens now and then. :)
Those that with an ability to educated guess properly on various stuff rumored
2080TI:
We should have calculators that tells us when we do punch stuff wrong.
(skynet helps)
Navi 21 is the bigger one. We don't know if the card leaked uses a cut down die??
n21.
n22
n23 as far we seen but then again, maybe smoke and mirrors from amd to aib to find leaks
so no actual pr benchmarks then so pulled out of someones backside like 99% of the stuff posted the past few days.
we all want amd to knock it out of the park, just dont start charging off down the rx570,580,590 ti killer path until we have some sort of actual idea.
same goes for nvidas numbers as well all we know for now is a 3070 is supposed to be faster than a 2080ti by how much thats debatable. as you cant even make guesses at if amd's cards can beat nvidias if we dont even know exactly how nvidias will actually perform.
So you're complaining about speculation on a speculation thread? WHy are you even here then?
I think its because RDNA and RDNA2 are not apples to apples, don't forget RDNA still has a lot of GCN in it, all of that is gone from RDNA2, the +17% IPC probably doesn't scale universally.
So no signs then? Do me a lemon and please, don't talk about our 'ability to educated guess' because time and time again we've proven as a community that we get it wrong almost all the time. Sepculation is one thing, but believing you're right without ANY information from AMD is foolish. But you go ahead, the rest of us will watch it all unfold :cool:
Status
