is there any possibility to mount a slim 120mm fan above? because the included 120mm press into my fuma 2 which creates some lag
I am really tired of this!
(but nicer/better tubing work)Watercooled vertical mount GPU - is this possible? I haven't seen anyone do it and can only assume it isn't possible; maybe due to vertical height / tube connection restrictions??
Anyone care to enlighten me?
Thanks
Cooler Master show it off with a vertical GPU on the product page. So it would be weird if it didn't work.
but no top fans, sorry i didn't specify that bit
Impressive getting the dual rads in there, even if one is missing a fan. Good to know it's possible without having to resort to extensive modding!
Is it just me that finds the love of matt black tubing in ITX rigs odd? Seems to be the done thing at the moment and take away from the interest in using water cooling imo!
He's waiting for it to arrive and will then add the extra fan.Do you need top fans with a fully water cooled system? If you do, it's going to come down to the height of the GPU. Most likely some will fit and some won't.
Hey all, I've been admiring all your builds for a while, they all look fantastic. I was wondering if anyone tried using a asrock B550M-ITX/ac in the nr200p and if there has been any incompatibility due to awkward cpu postioning as with some other mobos? thanks
Oh, I thought the comments said it would clash with the clips for the RAM? Looks like it would. I'll reread tomorrow when I'm more awake!He's only missing a fan because he doesn't have it yetHe's waiting for it to arrive and will then add the extra fan.
You'd still want to get rid of the hot air, so fans would still be preferred for the airflow. Looking at the Cooler Master promo picture front fan is blocked because of the power cables from the GPU and rear fan is blocked because of the termination. I thought this would be lower, but I guess the cards are wider than I thought. That means you really would only have the bottom radiator with its fans and nothing else. Might want to put a REALLY fat radiator then
All depends on space though, Alphacool NexXxoS XT45 would probably then only fit with thin fans, so may as well have a 30mm thick with 25mm fans. Doubt a Alphacool NexXxoS UT60 would fit![]()
Apologies, you are completely right.Oh, I thought the comments said it would clash with the clips for the RAM? Looks like it would. I'll reread tomorrow when I'm more awake!
Also, the tabs to release the RAM prevented having the 4th Noctua fan to be installed. No issues with temps with only 3 fans, though.
