Why do some ppl want RDNA 2 graphics cards to have HBM2 memory? Memory bandwidth is likely to be the least of the RX 6000 series' problems.
Using HBM2 rather than GDDR6 will just add to the cost too and require more power that could be used for other things like higher clocks or more CUs. Probably better to use a higher spec memory bus to increase memory bandwidth.
HBM2 is lower power draw, so you’ve got that bit backwards.
As for why, I think most of it stems from the rumour that the bus is 256bit even on big dog Navi and the assumption (Rightly or wrongly) is that it will be limiting on a card that is supposed to compete with the 3080 and GDDR6X on a 384 bit bus.
Had the rumours continued to point towards a 512bit bus and GDDR6 I guess there’d be less people hoping for HBM2.
