Reasonable.
The +50% from GCN -> RDNA was from Vega 64 to 5700XT. The worst RDNA did over Vega was Vega 56 vs 5700XT where the perf/watt increase was 49%
Your napkin maths is, how should i put this nicely, D+ at best hambug.
5700XT power per watt lead vs Radeon VII is
21% ( 1080P )
14% ( 1440P )
9% ( 4K)
15% overall.
If you get same uplift on the RDNA2 expect 15% across the board.
Do you think there will be improved RDNA 2 GPUs, built with 5nm or 7nm EUV in q2/q3 next year?
The Radeon VII is not RDNA and it (at least on that slide) is not GCN. GCN on that slide could be anything from Polaris or older but its not the Radeon VII, that was never intended to be a gaming card, its a bastardized Radeon MI card rebranded as an act of desperation to fill a gap between Polaris and Navi 10.
They are not comparable.
Moores Law thinks AMD think they can compete with the 3080 without the 80 CU Big Navi. i think he's right.
In the GCN comparison vs Navi 10 is as follows. https://d1io3yog0oux5.cloudfront.ne...gy+Overview_AMD+FAD+2020_For+Distribution.pdf This is the full presentation. On a previous slide they break down the 50% perf/watt gain and point to end note RX-362 where it says Testing done by AMD performance labs on June 4 2019. Systems were tested with Intel i7-5930K CPU @3.5Ghz (6 core) with 16GB GDDR4 @ 2133 Mhz using an Asus X99-E Motherboard running Windows 10 Enterprise 64 bit (Ver: 1809, build 17763.053). Using the following graphics cards. Navi 10 (driver 19.30_1905161434 (CL# 1784070)) with 40 compute units, versus a Vega 64 (driver 19.4.1) with 40 compute units enabled.
As it so happens the actual gain over Vega 64 was 63% perf/watt in the computerbase.de test suite and 59% perf/watt in the Techpower up test suite.
EDIT: The RDNA vs RDNA2 is RX-325 which just says Testing done by AMD performance labs on 06/01/19* using the Division 2 @ 25x14 Ultra settings. Performance may vary based on use of latest drivers.
* Guessing this is M/D/Y
Optimistic, I can see it competing with the 3070 though right in time for Nvidia to drop the 3070ti 16gb that wasaccidently leaked on a websiterumoured to come out at some indeterminate time in the future.
ExactlyRadeon VII and 5700 XT is an ideal comparison, as they both built with TSMC 7nm.
No, because AMD will have moved onto RDNA 3.Do you think there will be improved RDNA 2 GPUs, built with 5nm or 7nm EUV in q2/q3 next year?
60 CU for Navi 22 =
60 CU for biggest Navi =![]()
Number e-peen and envy. makes me laugh that some keep going on about transistor count and density like it's a super important metric, and X company needs a die size of A in order to compete with Y company. It's one of many reference points to consider, not the be-all and and-all metric.Why does it matter how many CUs there are? If 60 CUs beats a 3080 does it matter at all that it's Navi 21?
Transistor density and die size mean nothing if one arch is vastly superior to another, if 1 transistor is faster than 3 of another, who cares how big the die is?
And we have a rough estimate of the xbox performance which has 52CUs and 1800mhz using the same architecture. Roughly 2080/2080s?*Rumor
We really don't have much to go on this time around with Radeon rdna 2 gpus. From the rumors it is alleged that the performance per watt has gone up from 50% to 60%. Also all remnants of GNC have been removed with RDNA 2 which will impact performance.
There is supposedly four skus. 2 in the mid-range, 2 in the higher end. I find it hard to believe that 60 cu's is the max. Top teir rdna2 is alleged to use hbm2/hbm2e.
Rumor does have it AMD expected the performance of ampere and was not impressed. Whatever that means. And contrary to the conspiracy that Nvidia is shortening supply I've heard that they just don't have enough units to sell.
Suggesting that is why AMD is so calm cool, collective and quite. AMD is expecting their units to be low up until they are ready to release.
I entirely agree, but like I said die size is just one consideration, and the example you give is a business and resource one, not necessarily a performance one. And certainly not the only metrix that will determine if they can top the 3080.For AMD die size matters because if they want to produce x cards that compete with the 3080 then the smaller they can make that competitor the fewer wafers used on GPUs and the more wafers in their supply agreement can be used for Zen3 and other higher margin products.
