- 17 Sep 2020
Ah fair enough, I should've thought about if you specifically meant non OC or not, I assumed you meant Strix in general - my bad!
All good, it really does suck that they're split like they are, maybe they're doing some binning? Only way that would explain why they've split it into OC/non-OC and in all honesty if I knew the OC was arriving first I would have just spent the £20 more for the OC rather than the non-OC.
With the website dying and reviews out I managed to catch reviews basically going "Yea these cards really don't overclock well or at all, GPU Boosting is good enough" and thats why I decided to go with the non-OC before just buying whatever page loaded first. Even the EVGA with the over 400 watt power limit doesn't overclock well, just apparently holds clocks at around 2025~2080mhz, in reality only gives what like 2 fps more vs the TUF at 1900mhz~1950mhz.
