I also stopped playing after reaching the 100 battlepass, sick of all the cheating going on and the company doing nothing.
Not sure when I'll be playing again![]()
Yep, highest is 94% after 3 games of Duos. I think the last time i checked core usage all 4 were on ~80%Is your CPU usage high when running MW?
Think I'm going to have to retire from Warzone, Tried getting along with it but too much REALLY odd stuff going on, From the weird performance stutters when in combat to the dodgy stuff some players are pulling off, When you watch them in the kill cam they know exactly where to go it's crazy.
Maybe I'm extremely bad at the game (most likely) but something definitely feels a miss with Warzone.
It would definately help fps if I had a newer CPU as I get no higher than about 140fps even when setting 1080p and lowest settings
This doesnt bother me though because I play on highest settings in 3440x1440 and have fps limited to 90 as i'm using a 100hz gsync monitor
Warzone is pretty much always running 70-90fps and standard MP 80-90fps
FYI it's clocked at 4.5ghz
First games in nearly a month last night and it felt really different. Movement felt quicker and finally my guns could do some damage in BR.
Didn't have any particularly good results but got comfortably higher kill rates.
One off or have there been some changes in the recent updates?
Just last night I came across an entire squad hiding under the ground (below a rock). Must be some exploit or hack. Things like this are hugely frustrating.
The occasional cheater don't really bother me, it's the wierd stutter I'm getting when in close combat with someone, I don't understand what's causing it.. Frames are in high 120s, latecy around 45,i have a 165hz monitor. Myrt soon as in close combat I get a stutter which gets me killed a lot, I don't get this on battlefield or any other fps online.. Just warzone
Try the Nvidia 445.87 driver if you are on an Nvidia GPUThe occasional cheater don't really bother me, it's the wierd stutter I'm getting when in close combat with someone, I don't understand what's causing it.. Frames are in high 120s, latecy around 45,i have a 165hz monitor. Myrt soon as in close combat I get a stutter which gets me killed a lot, I don't get this on battlefield or any other fps online.. Just warzone
Are you referring to an FPS stutter or a character movement stutter? It sounds like the former. I’ve been experiencing a character movement stutter (rapidly hopping forward and back a step or two with no control input) like there’s some sort of connectivity issue. I’ll briefly loose control of my character and then, when I watch the kill cam, my character is still but on my side he/she is hopping about.
Just had a couple of games on Shoothouse and someone was using a RAM 7, I picked it up off the floor and it was beastly.
Never really used the RAM 7 but it was already levelled up quite a bit I expect due to Battle Royale use. Have added the 50 round, short barrel, tactical supressor, commando underbarrel and 4x flip scope. Short - Mid range (about 50m) it seems to hold its own better than the Grau even though range accordig to 'green bars' shows as being less.
Do you have any recordings of the stutter? Do you have the same problem in the pre match warm up? Do you stutter around team mates? Any idea if you are just getting bad frame times, obscured by FPS counters.Character movement, its as if there's a stutter soon as they fire,Yet the frames don't drop.
have you checked your render resolution is 100 ? mine has changed at least 3 times for no reason. also try full screen borderless.
Mine resets every time I launch the game :/My game always seems to revert to 66% render resolution after an update (1080p).
I notice that when im clicking around in other windows during the gane launch it will revert to fullscreen boarderless.My game always seems to revert to 66% render resolution after an update (1080p).
