Kick in the teeth to everyone who has one or had one on pre order.
If they cancel could be weeks / months of more time waiting for another brand and also the risk of having to pay more.
I would suggest hanging in there if you have a Zotac Trinity on order.
Firstly, Steve at Gamers Nexus has shown that there is generally around a 3% deferential between base line and the current highest tier of cards. So currently there isn't really a top tier card that provides a great deal of added performance for the often significant price increase. This may change but that's the current state of play.
Secondly, the consistency issue mentioned by the Zotac rep appears to be caused by fluctuating boost clocks as a result of a different thermal profile and a passive default fan setting. Basically you need to keep this card cooler to achieve comparable boost clocks to the FE and the default fan settings are prioritising noise levels as opposed to thermals. Early reports of people with the card seem to suggest that it can achieve comparable boost clocks to the FE with a more aggressive fan cooling profile.
Thirdly, Zotac seem to be transparent about this and seeking to find answers. A bios update has been mentioned. An updated thermal profile and default fan setting seems very achievable. A change to the power limit to match the FE could be more challenging or not possible. I guess this will depend on how much the admittedly weak PCB can handle.
My plan is hang fire and see how all these factors develop. If more information comes to light around the Zotac being a dud or AIB cards start really getting meaningful gains then I will revaluate. Its not like the card is coming tomorrow so time is on my side. Also the price paid is key. I paid close to FE prices and so can accept close to FE performance IF I get my card soon-ish.
Please let me know if there are any glaring errors in my plan!!
The bottom card also doesn't have the black component on the left (that is highlighted with yellow circle on top pic) - it's just hidden by the long brown thermal pad.Here are photos showing the Zotac PCB vs my Palit cards PCB.
I have added yellow circles showing something that isn't on either card that is present on the other card.
I'm in the same boat. From my understanding it's a 1-3% performance lost in some titles. I'm not bothered.Can’t decide whether to cancel both of my Zotac orders and join the back of the queue :/.
mid I did not sure which card I would go with anyway...
Only if it can stay below 336W stable from what I've read. Otherwise, it's a limitation of the fan curve which can def be targeted by a BIOS update.Anyone with knowledge of GPU’s have any idea if this is something which could be improved via bios?
