Got both my case and power supply off the well known used and new online marketplace in the last few weeks.
More expensive there though
I installed two slim Noctua fans in the bottom. Anyone else find that the blades scrape the metal? or I have I just screwed them in too tight?
Has anyone found any tower aircoolers to fit that expel air upwards (i.e. can be rotated)
Thanks
Just watched a video with the Arctic Freezer 34 Esports Duo fitted in the NR200 with a vented side panel.
Anyone have any experience with that cooler and AM4?
They actually produced a 3D printable bracket for this very purpose.
BTW Cooler Master should be commended for a GREAT case. They have made SFF builds easily within reach for anyone with the price point and have a case design that is well made with a lot of options for builds. I have now tested with air and AiO cooling and both work great.
') to know until someone has tried it. But I'd guess there will be a few millimetres air gap with 25mm fans.Are there any mm left with the 5700XT? I'll have to measure when I get the tuf card perhaps and see how I'll do it.The card is 51.6mm thick, so 25mm fans won't fit (it's a tight squeeze with the 49mm 5700 XT Nitro+).
As for deshrouding, it'll be tuf ('') to know until someone has tried it. But I'd guess there will be a few millimetres air gap with 25mm fans.
I see, well might not use the bottom fans alone. But if I can use some fans there instead of the stock GPU I would like that.I'd say no. Unless the card is perfectly level, the GPU fans scrape on the case fans.
I stopped using bottom fans though. Didn't seem to be really doing much.
Found that my stock fans resonated quite badly at some frequencies which annoyed me, so swapped them for a pair of Corsair ML120s that I'd bought pretty recently. I've not noticed any resonating with these and they've got a huge PWM range so can go from being silent to shifting serious amounts of air really nicely. If you aren't having any issues with the ones you have I'd doubt that you'd see worthwhile gains on switching to some Noctuas for the price of them.
