££ each
Cor, nice deal! Thought they'd be more like £200 each.
££ each
Ideal tyre choice for a van that.
To be fair, "ideal" for a van or not, they are an excellent summer tyre in all respects.Ideal tyre choice for a van that.
I quite agree
But presumably there is a specific range of Michelin tyres for vans for a reason..?
Also, the Caravelle is classed as a diesel car, so![]()
In the same way a Transit Tourneo is, which is also a van.
Its performing car duties though, so I don't see the issue with putting car tyres on? Its just a big heavy square car.
I'm just jealous as 4S wasn't available in my size.
Is it the Michelin Pilot Sport 4 you all recommend?
225/40 R18 Y (92)
Pretty much. Although the Goodyear Eagle F1 Asymmetric 5 is pretty much as good too. And money off just now at Costco, so you get a set for £57 each corner in that size.
Yeah keep seeing this but I'm not a member.
Can you just have the delivered and not fitted? I, like most of the country, live 50 miles away from my nearest one.
They are very well regarded.Just about to get 4 of these fitted: Goodyear Eagle F1 Asymmetric 5 hope they are good!
What do people reckon to Pirelli P7 Cinturato's?
Average. But would depend on what size tyres you need as to what better options are available
