Nothing to say it'll beat a 3080
16gb vram
Do an NVIDIA, set the MSRP at £14.58, but make sure there is no stock at sell them for a bazillion pounds each?![]()
5700 XT pretty much equals it in performance while having 25% less teraflops.
On the RTX 2000 series release, didn't someone say we'd need about 2,000 times the compute power of those cards to do full-scene ray tracing.Raytracing ain't free, the only time it won't be jeapoardising FPS is when (around 2030) games will be ray-tracing only, so no point of reference to compare in terms of lost frame rates.
4k is particularly difficult for ray tracing since it's a lot more pixels.
Ratchet and Clank on PS5?We haven't seen it demonstrated in games yet.
Nothing to say it won'tNothing to say it'll beat a 3080
That's what rdna1 had already done last yearso far, all we've heard is around 25% uplift in performance vs GCN.
We are very unlikely to see a 100% improvement in performance vs the 5700 XT (even with 80 CUs), because clocks over are supposedly limited to ~2500mhz with RDNA 2. Perhaps a 33% increase in clocks would be possible?
AMD could only achieve that kind of performance improvement with a massive improvement in IPC. So far, all we've heard is around 25% uplift in performance vs GCN.
It should be referred to as 25% IPC uplift vs rDNA 1, not Vs gcn then was my pointRDNA1 had some GCN elements left over in the architecture apparently, RDNA2 is a fresh slate hence the uplift.
You are saying that a card with literally twice as many CU’s, potential clocks up to 2.5ghz (seems too high to me but I’ll take you at your word here), and with IPC gains over RDNA1 can’t double performance?
