I think you will find the MLCC are the expensive groups of small caps the Cheap ones are the six single blocks ie POScaps.
From report
 large-area POSCAPs (Conductive Polymer Tantalum Solid Capacitors) are used (marked in red), or rather the somewhat more expensive MLCCs (Multilayer Ceramic Chip Capacitor). The latter are smaller and have to be grouped for a higher capacity.
According to the list and specifications of Nvidia, both are possible. In terms of quality, however, good MLCCs are better able to filter the very high frequency components in particular. In the end, this is simple practical knowledge, which only often enough collides with the world view of a financial controller.  If one searches the forums, it seems that the Zotac Trinity is particularly affected when it comes to instabilities starting at certain boost clock rates from around 2010 MHz. A feat, because Zotac is relying on a total of six cheaper POSCAPs."
