NV fixt it up TODAY with drivers
There's going to be a lot of regret from everyone cancelling their card if this turns out to be a trivial software fix with no impact on performance.
Most of UK Distance Selling Regulations is based around at time of purchase that a contract is agreed upon, on both sides, with a ETA given clearly and delivered within 30 days.Just curious how you believe that OCUK broke consumer law here?
Again, assuming the databases is accessible and not obfuscated in any way. I have worked on DBs that were in 5th normal form with completely arbitrary design. One I recall, had hundreds of tables with four letter random character table names. It was all generated code and not something that could be easily picked apart. I have spent days going through tables just to build a very basic view. Not saying this is the case, but just pointing out your assumptions are big ones.
Also, forget about making a direct connection into the DB from a web form hastily put together. Even if you have correctly set the permissions to read only, you are risking access to a bunch of confidential data as well as a new vector for DDoS attack. Personally, I would be hesitant to risk an ICO fine in the millions, for a single product, for a subset of customers.
Just trying to point out that this really isn’t as easy as you say. But I do agree that OCUK should provide more information such as orders per card, cancellation rate, etc.
How long did it take for you to get your money back?Just cancelled my Asus TUF as ordered at 9pm on 17th. Was lucky enough to spot another retailer selling some last Friday and nabbed one. One less in the queue.
not at all no. the voltage tables are messed up. Simply setting a stable maximum 1V is enough to solve this crashing issue. this will not downvolt anything as the card only needs 1V anyway to keep the boosting to 2ghzthey can not change what is being done with capacitors through firmware so they expact us to downvolt all cards?
Which retailer?Just cancelled my Asus TUF as ordered at 9pm on 17th. Was lucky enough to spot another retailer selling some last Friday and nabbed one. One less in the queue.
Swiped from reddit, wtf were evga thinking.![]()
If EVGA sent the googley eyes out with the card... I think they're on to a winner tbh![]()
Rather than flood post with key points (as they can all be argued differently at moment due to lack of clarity) here is a basic link - https://www.gov.uk/online-and-distance-selling-for-businesses
Key points from our perspective is if OC is indeed changing the queue, further delaying our orders, without warning or notice, that is easily a breach. Not only that but can be considered unfair favouritism of sales.
Minor things to nitpick:
You then got these ontop - https://www.gov.uk/online-and-distance-selling-for-businesses/online-selling
- delivery arrangements, costs and how long goods will take to arrive.
- conditions for money given as a deposit or financial guarantees. - Should include code as advertised at point of purchase. I ain't paid £50 over original advertised price to then lose another £50 game code on top.
- deliver the goods within 30 days, unless you’ve agreed otherwise with the customer - Could be argued for the codes.
I aint a lawyer, but have dealt similar cases in past. IT all depends on how technical you want to dive, but short answer is, if they are knowingly allowing queue jumping, then yeh...
I posted they using 470 same as Gigabyte they "should" be better quality than 330's and 220's but that requires also check of VRM's quality how much extra filtering is needed. Also MSI got 5+1 configuration as You see
Worry not. I'm about to start digging in to parts catalogues to check differences between types used by different brands.
Looking at these pictures it looks that you could replace the cheap chips with the more expensive ones I wonder if you could change them all?
but please don’t fall for cheap and more expensive please that is not the case same as people saying the good and bad ones Both have plus and minus neither is better overall vs the other.Do you think it would void the warrantee if you changed the capacitors yourself?Looking at these pictures it looks that you could replace the cheap chips with the more expensive ones I wonder if you could change them all?
Lol. Won’t be far off. That said you can always say yeah but 10gb is not enough, need 24gb or new games won’t run properlyYou can have the last laugh when your card does the same FPS as mine hahahah
If
thats what der8aur is doing at this very day on 3090Looking at these pictures it looks that you could replace the cheap chips with the more expensive ones I wonder if you could change them all?
100% but i repair pcbs all the time. if you could get one on the cheap worth a shot is what i am trying to say lolIf
