CX support freesync. Tell me which AMD card has hdmi 2.1 and support hdmi forum vrr so I can test?
BTW, sitting on your behind waiting for someone else to do something so you can benefit is terrible way of doing business. Nvidia did the work and certified 2019 LG line, even with xbox you can use vrr.
Have I upset you some how?
2.1 is needed for 4k/120hz , HDMI 2 will do 4k/60hz vrr
How has AMD sat on their behind ? From what I remember it was AMD that pushed for VRR to be put in the spec in the first place
Regards the LG range, Nvidia has certified them for use as a "G-sync compatible" then pushed their branding on the box, Nothing more, nothing less. Nvidia/G-sync is not even mentioned anywhere in the settings of the CX only AMD Freesync
And Nvidia has done such a fantastic job certifying them too, broken 4k/120hz g-sync with LG's latest and greatest
Regards the xbox , I think you've faied to realise/remember that the Xbox has AMD CPU/GPU in it too
