- 30 Nov 2011
Hi I'm considering getting a quest 2.
For a newbie entering VR what games would you recommend off the bat?
Also (using quest one experience) are the graphics reduced for the quest when not linked to the pc for most games?
I've got a 2700x and 1070ti. Would I be able to run alyx?
I'm thinking a quest one with a lower res might be a better option?
Quest 2 will always be the better option because of reduced SDE, you can reduce the render resolution in Steamvr when running pc games like Alyx and the image will still look better on a Q2 than a Q1
Alyx has auto resolution as well anyway, so it will dynamically reduce the resolution to try to stop you GPU being overwhelmed
