Its difficult, what are you going to do?
Re: my earlier post. So i'm looking for an 8 core CPU, 5800X is too expensive, 10700K is only £375, Intel are now the budget brand....
But hold on, thinking again. AMD's IPC is now so high the 8 core 16 thread 10700K is still a worse CPU than the 6 core 12 thread 5600X, Single thread performance AMD are just taking the pee at this point Intel cannot get in sight, Multithreaded performance because the IPC is so much higher than Icelake is not going to be any faster if even as fast as the 6 core Zen 3, which will run at 80 watts tops, vs 200 Watts, and £280 vs £380 of the 10700K.
AMD are in a position to make Intel look bad no matter which way you look at it.
